Identify Tranny/transfer Case
I want to do oil change on my tranny and inspect it. How to i identify the tranny to get the right filter and fluid, and how MUCH fluid too. I dont know if I have an Allison or not, I do know it has 17 bolts and it's rectangular pan.
Also want to do change on transfer case fluid as well, same thing....how do i find out whats there. I know the capacities from the manual.
thanks
thanks
Do you have a 6.0 or an 8.1 gas motor? If you have the 6.0, you have the 4L80 transmission, and most likely the NVG 263 transfercase. The 8.1 has the Allison. Being a "manual" transfer case (as in no Autotrac) you should put Dexron 3 or your dealer should have GM Manual Transmission and Transfer Case fluid (thats what the bottle says on it). Should be red. The blue stuff is Autotrac. As for the transmission, Dexron 6 is what you would use.
Well i got the 6.0 gaser so the 4L80 and the filter is IN the pan right? and whats the 4l80E?
..ok and the transfer is NVG 263 are you saying there is no autotrac in both? I think thats in the manual anyway.
thanks for the info :)
/quote]
you would use.
manual anyway.
4L80E is the automatic transmission paired with the 6.0. Its just the way GM names them. 4 means its a 4 speed, L is for longitudinal (rwd) 80 is the rated capacity (?) I think and E means its electronically controlled. And yes, the filter is in the pan. If you had the Allison, you would have both an internal pan filter and an external filter.
As for Autotrac, 2500hd trucks do not have it, and to my knowledge, never have. The autotrac transfer cases are found in Z71 1500 trucks, Tahoes and 1500 Suburbans, and I believe it may have been something accessible on 1500hd when they were made.
Per GM, both electronically shifted and manually shifted transfer cases are "manual" in that they cannot "automatically" engage 4wd on their own.
You were able to get the Auto-trac unit in the 01 to 04
GM 2500 LDs !
You have a 06 so prob. a NVG/NPG 263
More specifically, it should be a 263HD. There should be a round tag screwed to the back half case on the bottom that has model and S/N info on it. Looks like the attachment.
All I wanted is to change the fluid guys...but I appreciate the info for the future.
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
