Interior Cleaning
I am looking for some good products that will clean the interior of my truck, what do yall use for the side panels and leather seats?
Give our Leather & Interior Cleaner followed by Leather & Interior Conditioner a shot.
Neither is leather specific (they don't need to be as modern leather is urethane coated anyways) so each can be used on any hard interior surface like your door panels, dash, etc. PLUS your leather seats.
The cleaner is water based and can be diluted for lighter cleaning or used straight to remove tougher stains like blue jean transfer on light leather.
The conditioner finishes with a low gloss, is non-slip, and has a built in UV inhibitor with SPF 65 (think of it like really good sunblock for your interior).
We also back these with a 110% satisfaction guarantee so if you buy them and are anything less than completely satisfied we'll buy them back +10% of the purchase price.
Here is where I've used stuff for a long time.
http://www.griotsgarage.com/
They also have a great adhesive remover for if you were to remove emblems. They have a good interior cleaner you might be interested in and some leather cleaners if you have leather. and a carpet cleaner if im correct... not to expensive. Probably about 10 bucks a bottle
I'm an Adams convert also.
Starting using them a little over a year ago and I WON"T use anything else now.
I can't say whether or not any other products are as good as Adams but I can GUARANTEE no other company has the customer service and support that Adams has. There customer service is Top Notch plus their forum is a wealth of knowledge from folks who take car detailing Seriously.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
