Replaced Plugs And Hesitation!
msark
On my 97 Tahoe w/ 5.7 I replaced the plugs with Champion 7940. They are described as OE Replacement. Gapped to .060 as the book and sticker say. Idle is perfect but it doesn't seem quite as smooth and there is almost a hesitation... Or is it just my worrying?? Mark
Possible that you didn't get a plug wire on tight? Or maybe the plug wires are breaking down after changing the plugs. How many miles on them? They are 14yrs old.
Yeah wires is a good start, if you havent replaced them in awhile might as well, and when your at it change the rotor and dist. cap for good precautions, will run smooth again.
Thanks for the help! I also changed my air filter and installed the heavy duty, heavy dust condition model. didn't pay close attention to what I was buying. Put the standard back and it seems fine now. Maybe it didn't get enough air with the larger, thicker filter media.... A good lesson!!
When doing a tune up you should always do it all...plugs, wires, cap, rotor...
Also Get rid of the Champion plugs, use AC -Delco. I dont like to use Champion plugs in my lawn mower. They may work ok in a Chrysler but...........
Something I was told, way before the internet was around, the AC part of AC-Delco is the guy that started Champion spark plugs in the first place, Albert Champion. As for which one is better, if the plug is the proper heat range, proper type, and gapped properly it will work just fine. Most, if not all, running issues are in the head of the user. The problems usually develop from not being the proper heat range, and can be diagnosed simply by inspecting the plugs. Just because the book says the proper cross reference is "x" does not mean it actually is. Sometimes you need to go up or down one in the heat range to get the proper plug for your exact requirements. A well trained/experienced tune-up mechanic will know what his region/area needs based upon his/her experience.
Correct. AC-Delco plugs for every GM application, period. I don't like comebacks.
BTW, to the OP, I've never seen a high capacity air filter cause a stumble/hesitation on one of these trucks. I've substitued the high capacity for every near or full time, off road application that I've ever seen on these trucks with 0 issues. I vote plugs as well. Been burned too many times by non-Delco plugs in GM vehicles.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
