Need Help Diagnosing My Front-end Troubles...
Hey Guys -
I need help diagnosing what the problem is with my front-end. The ride on my truck has gotten worse and worse over the last year, until now when I've found that it's super crappy. Any little bump, pot hole or imperfection in the road makes the truck shake and jump all over the road. The truck has just shy of 50K miles on it. I don't use the truck as a trade truck, but do load it up from time to time. I also don;t drive like Grandma Moses, but I don;t beat on it either. The truck is a 2006 1500 4x4 Z71.
Here's what I'm thinking:
Tie rod ends?
Shocks? (visibly rusty and nasty looking but no leaks)
Wheel bearings/hubs?
Anything else it could be?
Here's a little back story. Last year I was having issues with my ABS kicking on a slow speeds and it finally threw an ABS light. For good measure I replaced both ABS wheel sensors, and while I was in there, brake pads and rotors.
Now about a week ago I'm starting to get the ABS engaging again in reverse at slow speeds over uneven terrain.
The truck is great at highway speeds, no shimmy or shake at all unless I hit a bump or pot hole.
Question is, how do I pinpoint the problem?
Anybody have an insight, experience, or diagnostic test I can do?
Money is tight right now, (got another kid coming early next month) I'd rather not throw money out the window on parts I might not need...
Thanks!
B
You could go to a good tire shop that does front end alignment checks for free and ask if your tie rods are worn beyond adjustment, and could check the shocks and what not,
Thanks! Unfortunately, I'm yet to be impressed by any local tire shop/repair center in my area... I always leave thinking "Geez.... What an A-hole!" :-\
But that may be the ticket...
Anybody living in Fairfield county, CT or Northern Westchester County , NY know of a good, reputable place you can recommend? :cheers:
You haven't altered the torching bars? Is the a-arm touching the min or max limiter(bumpstop)?
Nope, I haven't touched the T-bars, and nothing is sagging under there that I can see. Really the only nasty looking parts under there (appearance wise) seem to be the shocks. They're totally pitted with rust all over them, but when I do the "bumper stand" test, it doesn;t look like the body does any excessive roll... :cheers: Also, like I said in my first post the shocks are not leaking (yet).
Thanks for the responses guys... I appreciate it!
Just because your shocks aren't leaking doesn't mean they might not be part of the problem. I know several people with '06 models that had the tie rods replaced under warranty due to excessive wear.
So are you saying it's probably both? :lol: I'm sure I'm out of warranty at this point...
Maybe I should replace the shocks first, and see where I am? Is there any particulatr test I can do other then jacking the truck up and looking for play when you "push/pull" at 12 & 6'oclock postitions? And if so, how/what?
Also, How do I rule out the wheel hubs? Are they noisy when they need to be replaced? Anything I can look for there?
Thanks again guys! I appreciate your time and expertise/experience! :cheers:
i would replace the tie rods. all 3 of my GMT800's have had the rods replaced around 100k, and when even just one is worn the steering becomes very sloppy
Anybody living in Fairfield county, CT or Northern Westchester County , NY know of a good, reputable place you can recommend? :dunno:
I live in Fairfield County....moved from Westchester County. There is not one tire shop that I could find, that I would trust. However, I take my truck to Ingersoll Auto Group in Danbury Ct. and have been treated well. They were originally a Saturn Dealer, and bought out Danbury Chevrolet. I always thought the service we got from the Saturn line was great, and that has not changed since they changed to Chevrolet/Buick/Caddilac. When you pull in for even an oil change, the valet drives over a set of ramps, that give a quick look at alignment.
Really, ok?! But then again, my truck only has 50K on it right now...I think at this point I have to go with a stage approach, I think I'm going to start with the shocks on all 4 corners, since I see alot of people on here complaining about the Z71 shocks going before 60K, if that doesnt clear it up Ill change the tierod ends, and go from there...
What do you think?
Thanks for the input!
B
Go find a friend that has a set of factory wheels and tires for your truck. Install them on yours and go hit the same road. Dollars to dougnuts the shake is way better if not completely gone. If it isn't, check the tie rods for looseness because the shaking probably loosened them up over time and replace the shocks.
HAHA...
Rick - I'm in the exact same boat. I grew up in Yonkers, NY and moved up here to Danbury a few years back. I actually bought my truck at Danbury Chevy before they moved over to the Saturn building. I wasn't super impressed with them when they were at the old building the few times I had to bring the truck in for under warranty issues, but maybe that's changed since they're Ingersoll now...
Thanks for the input! Maybe i'll see you around town.... ;)
Bruno
Thanks! I still have my stockers, I run them in the winter months. The truck drives slightly better but not much with them on, For sure stuff is worn out under there... Thanks, I think I can't go wrong by changing the shocks then going from there, I'll jack it up this weekend and check for looseness.
I appreciate it guys!
B
A few things that I found that could be an issue. Check the bumper bolts. I had a loose one on my truck and when I hit bumps, the bumper shook. That was one issue. The other was the shocks. Replace them with some good ones, don't go cheap and they'll last longer. I recently replaced my wheel hub assemblies. They had a slight grinding noise when spun, but the wheel had no up/down play. That helped. I had one replaced at 8k miles under warranty and now both at 100k.
I still have something that bounces around when I hit a man hole cover or speed bump that I haven't located. I just replaced the shocks again, so I know it isn't them. I'm going to look at motor mounts and bushings tomorrow. I'll find this if it kills me!!!!
Interesting... ok i'll have to get under there and do some more digging around. As for the shocks I was thinking Bilstein 5100s, apparently alot of guys on here had had good luck with them.... What do you think?
As for the wheel hubs, I'm wondering if something fishy is going on with them. I replaced the wheel sensors on both wheels last fall, and now ABS is starting to act up again intermittently. But I'll cross the bridge when I get to to. A mechanic friend I have told me to replace the hubs as a when I told him about the ABS acting up, he told me 90% of the time you end up having to do it, of course I didn;t listen and only did the sensors . Oh well... live and learn...
So after all your guys suggestions I think I'll get up under there and dig around. Replace the shocks, drive it for a while to see, Then replace the tierods next if necessary, then look at the hubs...
Thanks for all the help guys!
I appreciate it!
Scott - Good luck finding your noise! I feel your pain!
    RSTRICK
    RSTRICK
  • Who's Online   4 Members, 0 Anonymous, 642 Guests (See full list)
    • Guys that read Dizzy's thread know that eons ago after multiple manifold pulls to clear the CCV orifice I converted it to a PCV system with an orifice below it via the valve cover. The blow-by (sticky rings) was so bad it was impossible to keep clean and accumulated water in the oil in the winter when the moisture would freeze in the fresh air side. The PCV functioning mainly as a check valve. I carefully sized the orifice to reproduce the factory values for crankcase pressure at idle.    Well...took a slug of oil to get my attention but the ring seal improvement meant the system was over drafting sucking oil up and out the breather. (V8 guys with orifice systems are nodding their heads). So today I choked it down...allot....to replicate the "just enough to hold a piece of paper on the fresh air side at idle". May still be to much but I'm working with shims at the moment. When I get it sorted I'll make a proper plate and plug. Perhaps using carburetor jets to tune it.    So I guess this means it isn't my imagination.    Dizzy is a pig guys so don't go expecting huge moves in equipment (your equipment) that is in much better shape. A needle valve....lord that just came to me....
    • I had a new engine installed with under 5,000 miles. It shut off coming around a residential street corner and wouldn't restart. Dealer indicated it seized. New one has been fine since with 10,000 miles on the replaced engine. Annoying but I was given a loaner for the 5 weeks it was down. I won't go with the 6.2l gasser so it's 3.0l again. I love the economy and it tows my enclosed car trailer just fine.
    • Coming back from towing a car to my daughter in Nashville truck started making a screaming noise from underneath.  Pulled over placed in park and sure enough whining noise from underneath.  Dropped at the dealer fearing new tranny or another front pump/cover replacement.  Service writer said it sounded like the tranny too...  Well $300, new idler and a belt all is good.  Pop the hood and give a listen. lol  Now I'm telling dealers I'm no longer interested in a new truck.
    • HD uses the 6.6 gas.   Oil consumption while heavy working is considered normal.  1 quart per 100 gallons of fuel is the normal rate above 8600lbs GVWR.  If more than that, it is considered excessive.   They will have to perform an oil consumption test using the guidelines in TSB 03-06-01-023J.     Information on Engine Oil Consumption Guidelines All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons, and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the combustion process, part of this oil layer is consumed. As a result, varying rates of oil consumption are accepted as normal in all engines. Oil Consumption Oil usage has a direct relationship with the amount of fuel used. The harder an engine works, the more fuel and oil it will use. Therefore, oil usage as a factor of fuel usage is a more accurate indicator of acceptable oil consumption levels than vehicle mileage for vehicles at or above 8600 GVW. The accepted rate of oil consumption for gasoline engines in vehicles at or above 8600 GVW is 1 liter (1 qt) within 400 liters (100 gallons) of fuel used. This rate only applies to vehicles under warranty, maintained in accordance with the appropriate maintenance schedule, driven at legal speeds and within design intent of the vehicle. Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pans, engine covers, and the engine oil cooler for leakage. Inspect for oil leakage into the engine coolant. Improper Reading of the Oil Level Indicator (Dipstick) The vehicle must be parked on a level surface to obtain accurate oil level readings. Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Not Waiting Long Enough After Running Engine to Check Oil Level The vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading to assure the oil has had enough time to drain back into the crankcase. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. High Speed or High RPM Driving Continuous driving at high speeds/high RPMs may increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer or hauling additional weight will increase oil consumption. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. PTO Operation Operation of a PTO will increase fuel and oil usage, as the PTO driven accessory uses engine power to operate. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution from Condensation On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).   Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase. Check the oil level and record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Next ensure the oil level is at, but not above, the full mark on the dipstick. add oil if necessary. Also ensure the proper viscosity and quality oil are being used as recommended in the Owner Manual Ask the customer once they have consumed 100 gallons of fuel schedule an appointment and return to the dealer for inspection. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, explain to the customer that their engine meets the guidelines for oil consumption.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
