New Hids And Truck Wont Start!?
I bought the hid kit from aandrmotorsport.com and i have done exactly as the instructions say to do. both of my headlights originally came on, but now the driver side wont come on.. this kit isnt just the "plug and play", you must run a wire to your battery and run another wire to a ground. with everything ready to go, my truck will NOT start. interior lights/dash wont even come on! i tried jumping it off and after 10 minutes of charging i finally got it cranked, but on the way home from the garage my truck almost died when i came to a stop (dash lights even went out for a sec) when i got home i cut the truck off and immediately tried cranking it back up, the dash lights wouldnt even come on. so i took the HID power wire off of the battery and it cranks RIGHT up. what could this possibly be?? hids shouldnt take that much power to start back up should they?
If one of the lights is not working then that ballast may have internally shorted, but I still don't how that could pull the battery so low unless you're not using a fuse. We had one to short and it would constantly blow 30 amp fuses, but when we hooked it up to the battery it burnt up the diode that was causing the short.
Definitely that HID system messing stuff up. Maybe it is putting a constant draw on the battery and the battery run down protection is kicking in and not allowing the truck to start. That kit was probably not designed with the fancy electrical system of these trucks in mind. You probably have a bad ballast.
i'm going to go out on a limb and guess you bought a 55w kit. i dunno why these cheap HID retailers sell a 55w kit cuz they always screw something up! you've got a 55w ballast trying to control a 35w bulb and its burning out the ballast which is drawing a lot of power from the battery.
i would get your money back and get a 35w kit, IMHO
Definately not the case here.. I have a 55w kit on my fogs and lows.. no problems at all, and i love the lights. Nothing but compliments. And the main thing is they are aimed right.. But that is off topic.
There is definitely something wrong with the ballast the way it is drawing so much power from the truck.. Or maybe that wire that is going to the battery... Where are you grounding this too btw? Could very well be a bad ground .
    ballencd
    ballencd
  • Who's Online   6 Members, 1 Anonymous, 667 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
