Well i had someone paint it and they sucked. Its peeling all over because they seem to have given up on sanding in certain spots. it literally looks brand new under it. So im gonna do it myself and add a billet insert afterwards. whats the process, what paints are you using? I did a search and didnt find much. Also if i have lifting, or divets from rocks how can i fix them?
I've been convinced that the only way to really get this done is professionally. Rattle cans are just too thin and lack real pigment. Not to mention the prep work involved. In order to get enough tooth in the part, you need to really scuff up the chrome, which isn't really chrome. Its a plastic-like chrome film applied to the base plastic. I'd suggest you either pay somebody who DOES know what they are doing or just buy a new already painted grille shell.
I would suggest buying the pre-painted shell. To really get the paint to stick, you have to sand off ALL the chrome overlay, and even then, it will peel once you get a few rock chips. I did this to an older S-10 with a phantom grille. The paint work was done professionally and it still peeled off
if pre-painted grill isn't in your budget, you gotta sand off the chrome like what jblaylock said, but you really need to use an adhesion promoter, then filler primer before paint. sand after you put on about 2 or 3 coats of primer to make it smooth, then apply at least 5 coats of color and 5 to 10 coats of clear if using rattle cans. once its cured, GENTLY wet sand with 3000 grit to remove any orange peel.
if you have metallic paint, have it professionally done at a body shop or buy the pre-painted one ifthey offer it in your color!
You need a good adhesion promoter, it is the most important part of painting plastic. The other thing is since it is a grill it gets hit by a lot of stuff as you drive so you want to pile on the coats of clear to it.
I've found paint easy to stick to chrome as long as you use etching primer, but now hard plastic is a different story, it loves to chip.
That's the problem. Under that chrome is hard plastic. Also, let me make you aware of how hard it will be if you sand off ALL the chrome. It will take you a LONG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! time. After your time/effort/materials...you could have purchased one.
If pre-painted isn't in your budget, I would then look at a black one, like on the base models. These would be much easier to paint. HERE is one cheap on ebay.
good find! i didn't even think of the unpainted plastic ones.
Im gonna have to think about just getting the pre-painted one i suppose. It sounds like the time and paint will add up to about the same.
That is probably your best option. You can also watch ebay for once, or search www.car-part.com and you may find a red one at a recycler....worth a shot.
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
