Transmission
thegater
new user
transmission repair topic is ?
How detailed will this forum be if I want to fix it myself ? Remove and replace if req. ????
Thank You
Ken
transmissions are not a do it yourselfer....take it to a shop or a dealer man to save yourself some rage and stress
^^^ +1 ... I hear that.
Been wrenching for 25 years ....... & it's bad enough getting the damn thing out, let alone dropping check balls & springs all over the floor ...
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
