Hi Everyone,
New to the group. My name is Ed--recently bought a 2002 S10 Z85 Crew Cab. Low miles (78K) and it appears not to be used to tow or other heavy work. Nice truck with the normal "things" wrong. The dealer filled the gas tank up when I bought it (nice thing to do). Anyway, drove the truck to get to know it the past week. The low fuel light lights up so over the weekend filled the tank up. Mileage is 187.5/13.1 so not abnormal. My question/issue is -- from empty to full only took 13 gallons of fuel. Yet the documentation calls for a 19 gal tank. What gives? Any help/ideas are welcome. Thanks in advance. Ed
2002 S10: http://www.new-cars.com/2002/chevrolet/che...ifications.html
Crew Cab had a 17.5 gallon capacity
Extended cab has an 18.3 and the Regular Cab an 18.0.
figure 5 gallon reserve if you fill right when the low fuel light comes on. also take into account that a near 10 year old vehicle will have sediment from the fuel at the bottom of the tank, though I can't believe it would offset the tank more than .25 - .50 of a gallon and even then that would be A LOT of crap in the tank.
old-chevy-dude,
Thanks for the info. will not panic next time and let the light be 'on' for 50 miles or so.....and keep a gallon of fuel in the bad of the s10. haha
13.1MPG?????? and you're not concerned?
My 2000 S10 got 16.5 towing a 4000# trailer (pictured below)
Hi Everyone,
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
