For those who don't know...
Kania2k1
So, come January 13th, I will be a Purdue Boilermaker. :eek:   Finally decided on Building Construction Management there.  It was a toss up between U of Florida for a masters of Purdue with a Bachelors.  Being I'm from Tennessee, I could never even consider going to Florida. :lol:  :lol:  :lol:  :P  :puke:  :puke:   Anywho, Ex broke up with me because she "needed a break"  whatever the h#ll that means.  But good riddence!  Not my problem anymore.  That was back in May, I think :lol:
 So, about 3 months ago, my co-workers played the "middle-women" and set me up .  Needless to say this girl was Fabalus!!!  I knew I was leaving in the spring, but that really had not hit either of us until recently.  We essentially had to go back to being co-workers and friends since she just started her Ph.D. here at U. Albany.  She can't really transfer now!  :(   We reached this agreement the other night.  Both of us took it kinda hard, I think.  I know I did.  But, each time we have seen each other, or leave each other, we kiss like we almays did.  What is this girl trying to do to me.  She knows I can't stay here, I'll find a clock tower and a deer rifle!  Or is she just looking to let me know we really can't get too involved, but we can still sleep together (actually sleeping, not any freaky-neaky  :D  :D  :eek:  :P  :D  :lol: ).  Ladies, the few we have, any advice?  Fellas, ask your wives if you must.
Congrats from a soon to be Alumni  :eek:
