Camaro Help
hockeypro1411
I recently bought a '99 Camaro 3.8 V6 5 spd manual to use as a work car and for the most part it's been solid. The other day I was driving normally, and all of a sudden I started hearing a noise that sounded like a bad rod knock. Upon further investigation, the noise is coming from the clutch area. It usually only makes the noise above 2k in all gears, but is worse in 1st and 2nd, however, it will still do it a little bit in neutral too. My technical knowledge of manual transmissions is pretty limited so I figured I'd see if anyone here had any advice to get me going in the right direction. Someone has suggested that it could be a broken clutch spring, and from what I read, that may be what it is. I just figured I'd try to tap into the wealth of knowledge floating around here as well before I dug too far into it :thumbs:
Release bearing will normally only make a noise when clutch pedal is depressed. Once the pedal is released, the bearing should not be in cantact with the pressure plate.
You may want to look at pilot bushing (or bearing). Does this car have the hydraulic release bearing, does it use the slave cylinder with a push rod and fork?
Does it make the noise with the clutch engaged or disengaged?
It may be one or more of the clutch disk springs. These springs are the ones in the clutch disk itself and are not servicable. You would need to replace the clutch to fix it. Those trans are not that hard to pull to check. If you do replace the clutch, make sure you have the flywheel checked and resurfaced if there are any marks or heat spots on it. Also make sure you replace pilot bushing and release bearing as well.
In my experiences with release bearings its actually the opposit of what you said...its exactly like the op described...it rattles when its not in use, as when its being used....its hydraulic in this car btw....it has pressure on it and doesn't rattle. I have found that worn pilot bearings on these engines cause binding and sometimes the inability to get the car into or out of gear...
Either way...yeah, you may as well replace it all when your in there like you said...another part will only fail a month after and you'll have to take it all appart again. And clutch kits are cheap for these cars...and pilot bearings are like 17 bucks...they usually put a new one in there for you when you re-surface the flywheel.
is it an nv3500 or variant that came in these cars?
if so its a throw out bearing, even if its not you will find it getting to the throw out bearing which will shortly need to be replaced anyways. Parts are really cheap, its the labour that costs...
No its a Borg-Warner trans.
Yeah, real cheap....like under 300 bucks.
Clutch is under 200 bucks, throwout/release berring (slave cylinder) pick what you want to call it...is around 50.
most machine shops charge like 25-50 bucks to resurface the flywheel...or you can buy a new one for 50-80 bucks.
Pilot bushing is about 5 bucks.
Job is simple on an f-body...bleeding the slave is the hardest part....it can prove to be a PITA
Oh and get a bottle of blue loctite for your flywheel bolts...
  • 4 weeks later...
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
