Spray Paint For Rims?
i was recently at the hardware store and found out that rustoleum makes high performance wheel paint thats suppose to halt rust and corrosion and look nice...i currently have steel rims that are showing signs of decay and i'm looking for a decent semi cheap fix aside from buying new wheels or powder coating...i just want to go flat black nothing crazy but i don't want it to look cheesey or cheap and i want it to last....any opinions? experiences"
Ive done it. I would definately suggest using Rustoleum products because they are cheap, but make a really nice end product compared to most other paints on the market. Ive even used it on plastics because of its nice finish.
The key will be prep work. Make sure you get all the old finish off of the wheel face. I suggest media blasting in a cabinet, or using a good quality paint stripper. Once the wheel is clean, you should wash it with a good degreaser, or hot water and Dawn dish liquid works. Then let the wheels dry completely and make sure they are within the temperature specs of the paint (as listed on the can). You dont really need a primer with Rustoleum products, but ite helps make a cleaner finish and helps it hold on longer. I always use a good clean metal primer before topcoating with color. I followed these steps and my wheel paint lasted for 3 years in sand and mud. You can follow with a clear, but its not crutial, especially if you are going with a flat color.
perfectly said, did this on my buddies blazer. use a clear coat ceramic engine enamel, makes it rock solid
Keep in mind though, I live in Texas so I dont get the winter salt like you northern guys do. Cant tell you how this process works in salty conditions.
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
