Got My First Deer Of Deer Season
Georgebaumann
well a nice 8pt buck decided to run out from behind a bush in front of my truck when i was doing 50. i hit it dead on with my push bar and it went under one of my 35's. needless to say i had no damage and got some venisen out of the deal :D
I read the title and was going to curse at you. I thought you got one hunting.
We have 20 more days till I can hit the woods after some backstrap.
20 days!?!?! Deer season has been in here for a couple weeks now!
Bow season has been open for a couple weeks here but need to wait about 2 months to go after one with my rifle
george i left you a comment about your lift and tires on one of your gallery pics (the side view of your truck) if you could respond id appreciate it. and send some deer jerky this way lol
Yeah, I envy you guys that get to hunt in August. But then I think about it, and I live in TEXAS where its still 100* so it may be a little too hot to hunt right now.
This. I don't want to fight mosquitoes while trying to hunt. Not in the 100's here, but its still in the 90's. I'm just looking forward to duck season.
Amen to that i love duck hunting! Im ready to get my weim in some ducks and let him retrieve em.
haha yah i skinned it up and got some nice meals planned. tonight is venisen chilli night lol andi never got a message.
Make some deer roll ups. Delicious. Cut deer into strips. Marinate in Italian Dressing for 8 hours. Cut jalapeno in half and remove seeds. Put piece of smoke Gouda in jalapeno. Wrap deer around jalapeno. Wrap bacon around that. Tooth pick through. Pop it on the grill. I swear I can knock out about 50.
Granted those are with duck same concept though.
Deer #1...
Deer #2
both of these were last year...
This bugger had a decent rack till i squashed him. 8,000#@65mph vs 180# @ 20mph... hmmm
The first one I hit at 70mph and the cruise control stayed on! hahaha
Deer #1...
Deer #2
You sir, need a deer basher on the front end.
    Smitty462
    Smitty462
  • Who's Online   5 Members, 1 Anonymous, 698 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
