Happy Birthday!
Spetember 30, 2010 I picked up my baby from the dealership. It's been exactly one year and I have put on 23,374 miles, going through 1439 gallons of gas. Other than the birth of my kids, and maybe my wedding day, this was the best day of my life. Bringing home my dream truck. Driving it off the lot, it had 131 miles on it. for my truck's birthday, she's getting a Recon light bar and tinted front windows. Unfortunitely, next week she's headed into the shop with a rear end problem, but I absolutely love this truck!
Congrats! Have you looked at custom dynamics light bar? I had the recon and liked it, but like the custom dynamics bar better :lol:
And you drive alot :) My trucks 2 months away from 1 year old and I've got 13,300 miles. :D
70 mile round trip to work and back. Took it to Cleveland and Michigan. other than that, it's a lot of softball games in the spring and gymnastic meetings in the winter.
Congrats
Man thats alot of miles. Mine will be 2 in Nov and I havent hit 20K yet.
My truck was delivered to the dealership about 2 hours before the birth of my son, I got a call from my salesman and first thing he asked was if my wife had the baby yet. I said no and he said well one thing has arrived. That was pretty cool and easy to remember :lol:
Congratulations on the first year!
Today is also my trucks birthday, but mine is turning 7. I'm just shy of 70K miles. It's not my daily driver or it would have close to 200K miles on it. My HHR that is a little over 2 years old is at 32K.
My 2010 GMC Sierra SLT turns a year old on Oct. 5th but I'm embarrassed to say how many miles I have on it, it's probably a record low for folks on this forum! ;-) I'm @ a whopping 3,800 miles in the past year so far! :lol: I split my miles between 3 vehicles so that's why the low #.
Congrats! :lol: I picked up mine Certified used with 29,49x on it two Septembers ago. It will have 70,000 on it by the time I get to Indy and back this weekend and the only issue I have had was a leaky oil pan, fixed under warranty a couple weeks back.
Congratulations! I had mine for a bit over 6 months, bought it with 8 miles on it. Currently have about 17,100 miles. Dash shows average 19.8mpg. Last tank was 20.9mpg. Love mine an not one single problem so far.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
