Free Oil Changes 2 Year/30k Miles
With the purchase of my new truck, I received a 2 year or 30k mile "free maintenance" program where they will change my oil, any other fluids, and rotate my tires at no cost. (Even though I was probably charged an extra $1000 for the truck :jester: ) They use mobil 1 dyno oil with the ac delco filters, but will only change it once percentage is below 20% no matter how long or mileage. I know the latest dyno oil is better than ever, but I also know my AMSOIL has always treated me well.
The truck is a 2010 5.3L 6 speed Z71 silvy with 12k miles. Would you guys do the dealer service or go with the better sythetic? :lol:
Depends on how long you plan on keeping the truck. If you will sell it or trade it in about 2-3 years, then go with the free maintanance. If you plan on keeping this truck for quite some time, then I would go with the Amsoil.
personally I wouldnt.
One reason is I wouldnt have time to go up there and have them do the oil change. I usually end up doing mine when a dealership wouldnt be open (weekends and evening)
Not me, I would pay for AMSOIL any day before I take anything else for free. I had a friend who recently bought a 2011 Duramax 4x4 long box e.cab 4x4 and he got a free oil change from the dealer. This past week he dropped off the truck and had them change oil. The GM dealer used generic Auto Value brand oil, the cheapest oil they could buy. He wrongly assumed they would use a name brand oil, at least GM oil.
With my CTS I get free oil changes for 4 yrs per the OLM monitor. Every fall I bring the car in to the dealer with my AMSOIL and they change it. I let them rotate the tires and sell me a filter and they only charge me for the filter and tire rotation. No problem what so ever from the service dept.
I got the same offer from my dealer, I've used it twice when I was in the area and didn't have the time to do it myself, The last 2 changes I did in myself and switched to Amsoil. I asked the dealer if I brought in my own oil would they still do the change and they said no, has to be from their supplies, so meh, if I am in the area fine, if not :shrug:
I usually change my oil late at night (say 1 - 2 in the morning) on a friday night after I get home from work, I don't like wasting my saturdays doing stuff like that, I work late most nights so I don't get to see my kid much so sat/sun is family time, I prefer not to be working on the cars, but spending time with my kid..
You're a smart fella. Time flies...
better yet have him help you
I was under my truck the other night and he pops his head under ( he will be 2 in Nov) and hands me a wrench (even though I didnt need it). Gotta teach em young. :thumbs:
Yea I hear you all. Yall helped confirm my thinking. :thumbs: Amsoil here I come again!!!
Ryan's right............... Some of my best memories involves Dad and me working on stuff. Truck/car/tractor/trailer/fence/house/shop/checking the cows/car shows....... etc.... You get to teach your kid something.
Whenever I have finally have kids, you bet ya mine will be in the shop. If they don't wanna work on their vehicles later. At least they will know enough not have have the wool pulled over their eyes, at a shop.
Jbo
    DaleB
    DaleB
  • Who's Online   5 Members, 0 Anonymous, 1,079 Guests (See full list)
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
