Remote's Work Half The Time
Hey All-
I've been having a problem with my truck since I bought the thing. Seems to be getting worse and worse as time goes on. The remotes to unlock or lock the doors do not work without me hitting the button at least 10 times. I have replaced the batteries in them twice and have held the lock and unlock buttons before in an attempt to re-sync them. The re-sync works and they seem to work better for the next few times, but slowly get worse and worse. I have taken them apart and cleaned the contacts on them too, doesn't seem to help any. Any ideas as to what might be going on or what I could try to get them working better?
Thanks!
Jeff
Has anything come unsoldered? If not might be worth stopping in somewhere they have a remote checker...... You take your remote in press the buttons and make sure its sending.... If it isn't sending...... geeeeeeeeeeeee, its gonna suck. Probably just need a new clicker.
Jbo
Hey All-
Thanks!
Jeff
Remotes are pretty cheap. Just get a new one and see.
