Could It Be The Bcm?
fighter42487
So my issue is this my intrament panel just stoped working yesterday. I have the speedometer and the Rachel working fine and my odometer works but nothing else . Door locks, power Windows, radio, reverse lights and keyless don't work. Could this be a problem with the bcm or something else ?
Could be a 100 (literally) different causes none of which, would be diagnosable over the internet bub. I'd take it in
and get it checked out.
Just updating the news. Took it in last Friday to the dealership they said it was the bcm that failed and had to order new one. So then on Tuesday I brought it in to install the bcm and that still didn't fix it. So I called up Friday And they are talking with Gm in Detroit on the problem. Still not fixed yet and I want my truck back.
Clusters are a known issue on these trucks, it probably has some faulty parts.
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 617 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
