LMAO
BDBWTE
That was, well, awful.  Some people have too much time, and just wasted mine!
:D
Ok I'm not sure I follow...Your on a discussion board your time must not be that important to you.  Aside I'm guess you can read and that it was a joke...and jokes are just to kill time and maybe get a laugh...that was the point but alas it has seemed to fail in your eyes..so for that I apologize.
:D
settle down.  I wasn't saying your post wasted my time, I was saying that people who make movies as such have way too much time.  Geez.
:D
You mean I was supposed to laugh at that display of pure uglyness?
If you call this >  :D   Laughing, then I was having a ball!
I would hate to be the one who had to compile the "keepers" that would go into the movie. Many, many, many bow wows there.  Chris Rock says women love to show off their ugly men. But, men will do anything to hide the ugly g/f.
