New guy from Texas
5280max
Hows it going everyone, I am a new guy on this forum. I drive a 07 silverado vortec max ltz 4x4 ext cab. I have owned this truck for almost three years now. I have been a chevy guy since day one! I have only had a few issues with this vehicle since I bought it but, they have all been fixed except for one that drives me crazy! when I come to a stop it feel like some one bumps into me. I have taken it to the dealer 6 times. First they cleaned and greased the slip yoke splines, then replaced the slip yoke with a nickle plated one, then they just greased the yoke every time. nothing has lasted more than a month. I have searched threads, I know this is a common issue but, has any had the transfer case output shaft replaced for this issue? I forgot the tbs # but, it says to replace the output shaft & to not grease the slip yokes on 4x4's. Should i be worried about all the grease they packed in there already? Any advise would be greatly appreciated.
No, you shouldn't be worried about the grease IMO. I previously owned an 07 vmax and had very little issue with the truck too. I never had the slip yoke issue on that truck, but my 03 I did. If you drop the drive shaft and re-pack the slip yoke splines with grease, that should take care of your issue. For me, It lasted about 10,000 miles each time.
Welcome to the site. :thumbs:
Just wondering if I should let the dealer tear into the transfer case if it is not going to fix anything. Thanks for replie
The grease was a one week bandage for this truck... Its been done a few times. I just delt with this problem since i have owned this truck. The bulletin # 09-04-21-003d is what i was referring to. Its states to replaced transfer case output shaft if the lubrication procedure has been done already.
  • 1 month later...
Changed both output shaft and drive shaft, not fixed, may be 50% improvement. GM must provide special grease for 4WD!
I wounder if # 09-04-21-003E is addressing this issue finally!
  • 3 weeks later...
Thanks for replie 4wd.... I took my pickup to the dealer again, they ordered the transfer case output shaft. So hopefully it fixes this one or at least makes it better. The last time I looked in my review mirror at a stop light after feeling a little thump! I was hoping someone really did hit me because I hate looking in the mirror wounding!
Welcome aboard I hope they get your truck straightend out. I had an 01 Duramax that had the "bump" feel just as you were hitting the gas pedal. I greased the splines on it with no luck and found that the rubber seal in the carrier bearing was shot and I was getting play in the shaft. However that was a 2500HD with a two piece rear shaft. I wish ya the best cause that stuff is damn sure aggravating.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
