Need your help on TPMS and different / larger tires & rims
Fallz
Ok , I have a Sierra CC 4x4 . It has a 2" leveling kit on the front . I called my local 4x4 tire shop who I have dealt with in the past . I am looking to upsize tires to a 285/65/18 ~or~ a 285/70/17 . These size tires are all "E" rated as I'm sure you all know that. They have told me it will be a problem because my TPMS won't register properly because of the much higher tire pressure with E rated tire and the light will stay on all the time. So if you guys can give me some education on this I would appreciate it. If I decide to go to 17's (my truck has 18's chrome clads) I can get tires and rims cheaper than the 18's so I'm not sure what I will do as far as that goes.
My truck is black and I want a simple type of rim without a lot of bling so I am going with AR 321 Fuel rims . I do not how to post a link or pic so I can't do that to show you , sorry .... The rims also have a clearcoat on them so it will be easy to clean and be protected a slight bit better with winter road salt .
I talked with them about tire's and I have had many of sets of BFG AT's in the past and they have been a decent tire but would like to try something different so I am thinking of Cooper Discover AT3's or GY Wrangler Silent Armor . I like the looks of the Duratrac's but afraid they won't be so good on hiway , ect.... and be to noisy . I do go off road but to be totally honest 99% is on road and in snow ect...
Give me your thoughts ect....
Thank you
Mike
I have 18's 295/65 on Fuel wheels with TPMS sensors installed running 45-50 PSI and all is fine.
I also have 275/75-18 on stock wheels with sensors installed and they are fine.
I don't think you will see a problem unless you run maybe 60PSI or higher.
Will the TPMS light come on if my tires are overinflated?
Not necessarily. The TREAD Act/FMVSS 138 requires the TPMS warning light to come ON when the tire pressure drops below 25% of the placard tire pressure. The TREAD Act/FMVSS 138 does not require the TPMS warning light to come ON when the tires are overinflated; however, there are systems available that do warn the driver of overinflation.
I have the Duratracs on my 2500. Noisy? A wee bit but nothing like you'd expect from them. Great in mud,snow and on the highway
I went with E-rated tires a few months ago due to I do alot of towing... I found everytime I aired up my tires to 70 lbs+ my TPMS light would go off so I went to the dealer to re-calibrate my system for up to 90 lbs of tire pressure and never had another problem. Dealer told me that when a person goes to a tire pressure greater than 50 lbs that the TPMS light will go off so made sense to me to have the system re-calibrated.
I have LT275/65/18 BFGs on mine and as cs said it will only give a warning if pressure exceeds 50 lbs. Unless towing pressures that high aren't needed, will make your truck ride way too firm. I normally keep my tires at 40-45lbs ( my tires seem to wear the best at this pressure) and air up when I'm towing.
My truck had 20's from the factory, and I replaced them with my current setup. The TPMS was looking for 30 psi from the factory, because of the P-rated 20" tires. So, I had the 'magic number' set to 45 psi when I changed to E-range tires. That way, I can run 40-45 psi all the time, and then bump up to 50-55 psi for towing.....and the TPMS light never comes on.
Ok thanks . That make perfect sense . Just gotta decide on tires .
The Rod , that truck looks sweet !!
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 522 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
