Air in my brake lines?
Hey guys, I did a rear drum brake change a few weekends ago in my 08 1500. Ever since, my brake petal has felt very week. I can easily bottom out the petal and that makes me nervous knowing I am going to be doing some towing in the near future. I thought that maybe I did not manually adjust my rear brakes enough after I put them on so I went back and readjusted them to where the rotor had some friction with the brake pads. I thoroughly cleaned the rotors and the brake parts when I changed the brakes. Also I checked the front brakes and they are still in good shape, I bought the truck used and im guessing they were recently replaced. Could I have allowed air to somehow enter the system while doing this? I never opened the brake system so I wouldn't think so but it sure doesn't feel right. Any thoughts? Thanks guys!
First make your fluid level is good. Then could try a couple of back ups & sharp braking. That'll further adjust your rear shoes. If that don't work then inspect all brake lines for leaks. If none than I'd proceed with full brake bleed.
Yeah I did the backing up and braking. Never seemed to help. I suppose ill check the lines next for leaks where air could get in. Thanks!
I'm not sure if I'm reading your post right...Did you change your brakes out from Drum to Disc?
Sorry, my words were kind of confusing as I used the wrong words a few times (rotors=drums, pads=shoes, etc) so no I didnt not go from drums to discs. I just replaced the brake shoes in the drum.
Make sure you installed the parts correctly. The rear wheel cylinders have small push rods on the ends that need to be properly engaged in the brake shoes to force them against the drum when hydraulic pressure is applied by pushing on the brake pedal. If parts have been installed correctly, then you have air in the brake system. Did you change out the wheel cylinders? Just changing the brake shoes without disconnecting the hydraulic system woudl not introduce the air into the system.
yes you have to bleed the system even though you didnt open it up.
No, you don't.
No, you don't.
No I did not change the cylinders and I rechecked to make sure the shoes were sitting properly on them and they were. I also went ahead and checked my brake lines and they look brand new and without leaks. The owner before me must have had new ones put on, they still had the barcode tags on them and they were all painted nice with black without rust. So what do you think, should I just bleed the system and go from there? I did notice that the master cylinder was not filled all the way but it is still in between the min and max line. Thanks for all the help so far, much appreciated!
Definitely bleed the brakes, starting with the right rear wheel cylinder, left cylinder, right front caliper, and left front caliper, in that order.
I dont know if this means anything but if I pump the brakes while getting ready to stop it stiffens the pedal. But it only does it for that stop, I have to do it again for the next stop.
Definitely bleed out your brakes as pm26 said. One way or the other you've got air.
Alright will do that. The last vehicle I bled the brakes did not have antilocks on it. Is there a different procedure or anything I need to look for when bleeding with my new pickup?
No, you don't.
OEM brake lines are black from the factory so those most likely are original lines. I believe they are nylon coated, hence the black apperance.
Now that I understand what your doing...
On drum brakes assuming you have the shoes installed correctly..Once you put the drums back on you'll need to adjust the shoes to fit firmly (but still able to turn) against the drums by spinning the star adjuster through the backing plate. If not you'll have excessive travel in the wheel cylinders.. This may be why you have to pump the brakes to get a firm pedal each time you stop.
If you didn't open a bleeder valve you "shouldn't" have air system but in your case it might be a good Idea just to make sure your lines are clear from any air once your rear brakes have been adjusted..Can't hurt!
    • I have ordered the car link adapter and registered for the google dev, will need to finish verification process later this evening when I get ahold of our kiddos android tablet. I will be using windows vs mac so hopefully it goes smoothly. I have zero tech background but I feel I can manage this with your write up.    Do you think it will be different for me? My truck is a 2023 GMC 1500, I have looked heavily into the AI boxes but I consistently find common complaints with lag.    Does carplay auto open now that you have it set up when you get in truck and turn it on? Or do you have to do open the app everytime?
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
