2008 Sierra Tow capacities
crepitus
Where can I find the towing capacities for my truck? I looked on the new and it says 4800 pounds. That seems low. I want to buy a Jeep to off road with and tow it to off road parks. My truck has the 5.3 with tow package and 3.73 gears.
I'd think you'd be in the 7700-8600 lbs range. My old 03 5.3 with 4.10 gears was rated for 8800 lbs :thumbs:
You'll be fine. If yours is 2wd then we have the same truck. Mine is rated at 7700lbs. However, the GCWR is 13000lbs and my actual truck weight is 5700 with a full tank of fuel. As a result, my tow rating is more like 7300 lbs. A trailer and jeep should be less than 7500lbs easy but you'll need to load it properly to watch the hitch weight. I believe the rear axle is rated at 3900 lbs. When pulling my trailer I get closer to my axle rating than anything else due to firewood, ice chests, etc.
