Front diff crossover
hitempguy
I'm looking at replacing my front diff, it is making growling noises when in 4 wheel drive. I have found a used diff to replace it.
My truck is a 04"Sierra Z71 Crew, VIN (last 10) T641352263 and the donor truck is an "06 1500HD VIN- U96F183496. Both are 4.10 ratio and GT5 option number. My concern is the splines for the axles not being correct. Can I use my stub axles in this diff? Any one out there an expert on this matter?
Thanks
1st off ,WTF are you doin buyin a used POS diff?????? do not buy it !!!!!! you are getting caught up in the cost factor ,and you WILL GET BURNED,,odds are not with you ...
you can answer this yourself unless its an online purchase by pulling the axle shafts and comparing the 2 (good luck as they CAN be a PITA to get out on some diffs
your truck is worth having the diff repaired
your VIN is incomplete,1/2 t or 3/4t ,,,,K1 or K2 ?
i just noticed you are from alberta ,dam it ,pm me ,
I guess the dealers can sort out the specs from the last 10 of the VIN
The diff is clean, 120 k on a rollover truck, all hwy/city
Mine is a '04 Sierra, 1/2 ton, Crew, Z71, front diff = GT5, 4.10, K1
His is a '06 Silvy, 1500HD, Crew, front diff = GT5, 4.10, K1
$350.00 seems worth the effort, about 1500.00 to get a rebuilt...
you had an estimate for the repair?
good luck to you i guess ,as for the vin , i meant you never mentioned what your truck was ,the whole vin shows K1 or K2 ,the last 10 shows engine and year only,
go to full size forum for VIN breakdown
have fun if you are doin the diff yourself
merry xmas whatever your name is !!!
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
