2011 HD Grille on my '07 1500
That looks great! Does anybody know if a 2012 H.D. one piece chrome bumper will fit a '09 H.D.?
The dealer can't tell me so I'll just have to wait to hear from someone that has tried it.
i don't see why not! the hoods, headlights, fog lights are all the same, so the grill is probably the same shape since it fits on a non-HD truck.
Looks good man. I personally like the looks of not haveing the chrome strip on the hood. But I would probably add the bug gaurd to get rid of the under bite as you said.
thanks guys. I flirted with the bug guard idea but I've never like them so opted not to run one. Ordered the chrome molding a few weeks ago (it's backordered). I'm on another forum where guys have done extensive conversions, and mounting the chrome molding on a 1500 hood can be tricky. I'll find out when it gets here. I didn't order the 2011 hood molding though, I ordered the '07-'10 molding. Which I believe will be easier to mount.
I also have an idea to fill in that small bumper gap that I'll be trying soon.
  • 4 weeks later...
got my bowtie and mounted the chrome strip on my 1500 hood. lovin it.
Too bad they didn't leave the factory that way...Looks great all finished!!
  • 2 months later...
My question is could you do this with a GMC hood and the Denali chrome hood strip it's wider I think? Love the GMC hood.
  • 3 weeks later...
I just did this with my truck and have the chrome strip sitting in my garage. I'm pondering how to apply it... How did you get it on?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,185 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
