2500 or 3500?
Get yourself a Diesel now, while prices are still somewhat low, though I hardly think $50,000+ for a 3/4 ton can be considered low :(
The 3500 is heavier than the 2500. Weight is the enemy of performance, handling and economy. The 3500 will use more fuel than a 2500 and will not perform or handle as well empty. Count on gasoline to be $6.00 a gallon or more in a couple of years - so don't buy more truck than you really need.
Published weights are hard to come by, but as I understood it, the only difference between a 2500HD SRW and a 3500HD SRW is the addition of the helper spring on the rear and the DOT certifications for increased rear capacity that that helper spring gets you. Most of the literature I can find on the subject seems to point in this direction.
The only weight difference between an otherwise equal chassis (same options, engine, bed/cab size, etc) is that of the helper springs. So the MPG and performance difference would be negligable at best.
In fact, if you look at the towing guide, the 3500 and 2500HD's hitch ratings are identicle, in the SRW configuration (if all engine/cab configurations, and gearing, are equal). You do get bigger 5th wheel and slide-in camper rating for the 3500HD thanks to the helper-springs in the rear.
Since the original poster has a slide in camper at the moment, even though it is a light one, I'd still recommend the 3500HD for the higher capacity should he wish to upgrade in the future (or tow behind the vehicle).
http://www.chevysilv...13silverado.php
If thats what they are going to look like, I am going to Ram.
Thats a concept that has been out for like a year and a half maybe 2. That truck looks like nothing to the thread I started on the new truck. http://www.gm-trucks...l=&fromsearch=1 or just go here. http://news.pickuptrucks.com/2011/11/first-spy-shots-of-next-gen-chevy-silverado-1.html
10 4, So how do i find out if i have a full or semi floating
The hubs on the ends of the axle are the dead giveaway. It has a series of bolts around the cap.
OOPS, things just got complicated. Go to this: http://www.rv.net/fo...4137/page/2.cfm
Saw this picture (maybe) of the new Chevy 2013/14 truck. So now do I wait for the new 2500/3500 models?
That is an old concept and NOT what they are going to look like. The new 2500/3500 trucks will get a new body like the redesigned 1500s that are coming in 2013, but the chassis and suspension will be carryover from the 2011 model years forward (just like the 07.5-10 HDs got the carryover chassis and suspension from the previous generation.
Well, if everything goes according to plan, I wont be getting one until around 2021. Gotta pay off my heap, then Im getting a Wrangler Unlimited Rubicon. Once I pay that off, I might be getting a new, or new to me, truck if the wifes car is still holding up.
2500hd will be more then enough...my honest opinion is that a diesel is the only way to go in a 1 ton...
    • It seems fine because it pulls everything out of a hot engine. I’m not going to worry about a thimble full with 5K oil changes with synthetic oil. Every other oil change is at Honda they pull the plug. I watch them through the process. It turns out going to Honda what amounts to their normal oil change intervals.
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
