Bigsteve_o Posted December 28, 2011 Posted December 28, 2011 Hi everyone, I'm new to the forum and was hoping someone can help me out? I have a 2003 Chevy Silverado 1500 2WD 4.8L V8 and the service airbag light came on but I am not getting any DTC's? Also the light comes off & on and it seems as if I'm getting low voltage through the truck when it comes on. Can anyone help me on this? Also when I plugged in my obd II scanner to see the code after toggling through my truck went completely dead as if it didn't have a battery plugged in, after a quick jump start it was back to normal. Thank you
2007silveradonbs Posted December 30, 2011 Posted December 30, 2011 A standard OBDII scanner will not pick up Airbag DTCs. You need a scanner that will read the airbag system. http://blog.airbagsolutions.com/archive/2010/11/11/which-scanner-do-i-need-to-reset-the-airbag-light.aspx
jaredlucky16 Posted December 31, 2011 Posted December 31, 2011 Might have to go to the dealer and them use a Tech II
gmtech4 Posted December 31, 2011 Posted December 31, 2011 i have seen some weird low voltage things happen,,, charge up your battery first and try and duplicate the concern
