headlights on 2005 Tahoe
Is it possible to get both high and low beam to stay on when high beams are put on??? My lights are adjusted where they are suppose to be by law but really don't do a good job of lighting the way I changed bulbs and everything but was wondering if I could get both on at same time??? or how to get more out of them without a lot of money???
There is a way and I belive there is a module that you can buy that bypasses the relay that swaps the headlights from low to high. Do some research, im sure something will come up.
That's probably illegal in most states. You would be blinding oncoming traffic with all those lights on at once.
He wants the lows to stay on when he hits the brights. They come from the factory when you hit the brights the lows go out.
LMC has one for like $25 easy install i bought it for my truck
Where are you guys driving that you need that much light? Going coon hunting? :happysad:
well in florida some hwys have no street lights and theres deer, and here in cali now theres places where there is like no lights so being able to see far and wide is good
So much for high taxes. Seeing is good then.
In kansas there's no street lights and tons of deer... Which is why I have the grille guard. I was thinking about doing this mod too, but I think I'll just go with LED lights mounted somewhere in/on my bumper.
Try using the "Silver Star Ultra" bulbs, they use stock wattage and are @ 4100K, they will project a "whiter" light, that is prasuming (sp) that your headlight lenses are not dulled from the sun.
Your bulbs should be:
9005 High beam
9006 Low beam.
    Mistycool
    Mistycool
  • Who's Online   2 Members, 0 Anonymous, 1,914 Guests (See full list)
    • I am having similar issues.. 08, 4.8L granted I did had a fender bender and minor damage up front passenger side but I don’t think it had anything to do with it.. I had the high and low pressure checked and my fan for my radiator keeps coming on.. replaced the pressure switch and don’t want to keep throwing parts at it. I did have some minor problems here and there like on long road trips sometimes the ac would get a little warm and then on the highway as soon as I give it a little gas or get a little heavier on the petal it started running cooler. Never had an issue with the ac besides the here and there.. but I also started having issues when I fuel up now it takes a bit to start ( super embarrassing) it runs fine and once started ( only happens after fueling up) starts fine any other time. Could they be related?
    • Spent a small fortune on fuel this weekend.   $6.69 diesel, 18 gallons of that. $6.99 92-octane ethanol free, 10 gallons of that for yard machines $5.59 87-octane for one of the cars, 11 gallons.   $250+ and I didn't even get a tug.   Hormuz ain't Hormuzin again, did not see that coming...LOL
    • Appreciate the advice. I've watched multiple videos. Most showing the most complex for those that have a center console, to one that showed maybe 2 pieces of trim being removed, like 6 screws, pulling back the screen and switch assembly, and installing the inline module. And this was a new/newer Silverado. That didn't look too bad. All the others show alot of trim pieces that need to be removed. I've broken those kind of tabs/clips on my C8 Corvette trying to get to the battery, and that was a lot less clips than what I think is involved here after watching multiple videos and looking at my dash today. I have one on the way. Called a reputable stereo place about installing it and got a "minimum" price of $175. Ouch! Looking forward to seeing what the instructions have to say.
    • Hard to say what the issue might be. Anything from the ability to cool the AC condenser up front, to blend door issues in the HVAC unit, to refrigerant charge, to compressor issues or issues in the lines.   Report back what the techs find on the 29th.   GM has service publications which list acceptable vent temperatures and AC pressures at given ambient temps and humidity. They probably won't touch the system if it's operating within those ranges.   I'm also surprised to hear your 2024 with the L8T is still using R134a? I was pretty sure the HD's had switched to the new refrigerant around 2020.
