coolant system bleeding on 05 silvy
brent shelton
05 silvy i just changed the thermostat andi need help bleeding the system also even when the motor hits 240 i dont have any heat inside the truck and yes i do shut it down at 240 210 is the normal operating temp please help thank u.
Did you flush the heater core thoroughly? Someone posted flushing procedure in your other post.
I meant to say the bleeding procedure.....
To flush the core, just remove the hoses and reverse flush it with a water hose.
Were you having a heater problem before changing the thermostat? Being low on water can cause a no heat condition.
