Deconstruction Posted February 9, 2012 Posted February 9, 2012 So the time has come to lift my truck. Its an 07 vortecmax CC in black I started working at an offroad and performance shop a few months back, I sell lifts everyday and drive my truck which only has a levelling kit. Just ordered my wheels today BMF SOTA's 20x9 in death metal finish. I will be running a BDS 4" High clearance and Bushwacker cut out flares for a little more wheel well opening and plan on stuffing some 275/65R20's or slightly larger in there. Later I will get a trail ready, fabfours or road armor bumper if I cant get enough clearance from the stock bumper anyone ever done this before? I know the usual way to run 35's is a 6" lift and still requires fender trimming. This wont work for me since I dont want to sit that high it will make it hard to get the motocross bikes in and out of the truck. either way I will be running this combination I just need to decide if I want to get the Fox Coil overs or run regular shocks in my truck and figure out if the truck needs balljoints again at 87000kms
redjewel2ss Posted February 9, 2012 Posted February 9, 2012 you could have a body shp neatly cut out the metal on the backside of each fender, then cover it up with the flares.... OR instead of buying fender flares, get some fiberglass prerunner style fenders and trim those to get the tires to fit.
Deconstruction Posted February 10, 2012 Author Posted February 10, 2012 Thats why I am running cut out flares, they remove and inch and a half out of the wheel well and then cover it up. The 275/65r20 works out to a 34.5 and just over 11" wide same as the stock tires I am fairly confident it will work if I have rubbing issues in the front it will most likely be from the front bumper which I am not scared to cut or replace with a trail ready, fabfours or a road armor. Later this month we are doing a 2011 rcsb chev with a 7" -24 offset cut outs and 36x15.5's my truck rubs right now with its stock 20's and 275/55r20's and with its 265/70r18 winter tires and wheels by trying new ideas we discovered you can run 305/55r20's with cut outs and a 1.5" level on wheels with 0 offset like my sotas will be
ruggedlife Posted February 12, 2012 Posted February 12, 2012 you'll be cutting metal for sure i did a set of novakanes on a 35 with 8" of lift and with that zero offset it just barely cleared
SouthCo Posted February 12, 2012 Posted February 12, 2012 Your rubbing with stock diameter 275/55/20's? That doesn't sound right. They clear with stock suspension and you have a 2" level kit which should allow you to even run a 275/60/20. I run 275/55/20's and they are no where near rubbing.
yukon25008.1 Posted February 14, 2012 Posted February 14, 2012 I can tell you from expierience to go bigger then 275 65 20! I had an 06 CC LB sieera d-max with 2-3" of lift and had 20x8.5 rockstar rims with wrangler at/s "silent armor" And i regretted it everyday!! They looked way to small,not so much hieght but the width, They just looked stock and to small under the truck.. Remember they came stock on certain yr f250,s.. Just wish i would have gone with 295/60 or 295/65,s Just do the research and measure before your not happy with your finished product. Good luck
yukon25008.1 Posted February 14, 2012 Posted February 14, 2012 The 275 65,s are only 34" tall x 10.82
jimmyboy8301 Posted February 15, 2012 Posted February 15, 2012 i've had many lifted trucks and 99.999% of people that go with a kit smaller than 6" regret it VERY fast. i would definitely consider the BDS 6" instead (almost the same price too). also i've heard from several sources that BMF has stopped production on ALL wheels due to QC issues. my BMF's are less than 2 months old and have LOTS of oxidation on the machining.
