battery goes dead too easy!!
Out of warranty..had it at dealer for repairs andit actually went dead on them recently.they quoted almost $200 for new battery and I declined figuring these batterys can't be worth $200 if they only last 3 years
Is the battery actually going dead? or is the truck just telling you the battery is low and turning the radio and all the other accessories off? I ask because there is an update for the computer for a known issue with the computers thinking the battery is dead when it isn't. Happened to mine, just needed a quick pcm update....
No its going low to where its not cranking over or barely does.radio and lights usually work,just not enough crank power
over here east penn canada battery from NAPA, the best battery if you are Live in Cold just like me
Me too! I went to Advance Auto parts all ready to buy a new battery and after checking it, they assured me my battery was fine. The 1st time, I had been working on the stereo but ran very little battery yet it died quickly. The 2nd time was at Discount tire getting a new TPMS and rotate. In that short time, my battery was dead again! This time I went to sears to buy a Diehard and again they checked it and it checked out fine. Is this normal? I do not want this to happen when I am out in the middle of nowhere. I was going to buy either diehard or Optima. My concern is do these trucks draw a lot from the battery when the ignition is on or what could cause this?
This exact thing happend to my 07 NBS Silverado at Discount Tire getting my tires changed /TPMS reset. That was on the OEM Warranty replacement battery, since the original died in a car wash. I got a jump went straight to the dealer and they were worthless, stating that the warranty replacement batteries are only covered for one year. I was at 16 months. I went to Autozonew and their equipment showed that it was toast, so i replaced it. I have also drained my battery in the parking lot just listening to the radio. I still think the battery plates are too small or bunched too tight in this battery which is leading to many premature failures in these trucks.
Did replacing it solve the problem? I was really thinking I was going to buy a Diehard, but with the reviews on the Duralast I think that is the way to go.
Ive had my truck 5 years and my battery is factory must be just lucky
youve got a few years left...mine lasted me 7...the stock ones are pretty good.
Actually I'll say this my battery was dead the other day... I should also say I hadn't started the truck in 4 months. Runs great now though!
I just had my battery (10 month old) replaced last month on my 2011 GMC Sierra at the dealer at no charge. The battery was almost completely dead after sitting in my driveway for ~5 days w/o driving. I was just barely able to get it start and I drove the truck around on several errands leaving running the whole time and I then drove it to Autozone to have them check the battery. AZ said the battery and charging system was working fine, but this did not give me a warm fuzzy feeling, since if everything was working then why did the battery go dead? I took it to the dealer and they determined the battery had a bad cell(s) and replaced it under warranty.
The take home message here is that you can't always trust the $100 battery testers these Auto Parts Stores use.
    • I'm suborn like that Ed. There's a plaque in my doctor office that says, "Don't quit, take a break." Works for allot of things.    Reality is, the wife loves her SUV and even given it's issues, she'd buy another if she found one with low enough miles. Then again she has me to maintain it.    Most of what ails this thing is GM shooting themselves in the foot and by extension the buyer. Besides a ridiculous breather system the cat warm up strategy, IMHO, is the dumbest thing I've ever seen an OEM do to a vehicle they warranty. On cold start it r-e-t-a-r-d-s the ignition to like -17* ATDC and dump fuel like kicking over a pail to force combustion in the CAT's for rapid warm up. This literally hoses the oil off cylinder walls and creates enough varnish precursors to stick rings in even well maintained engines. THEN if that wasn't bad enough they recommend using a wanting fluid specification at equally stupid interval.    Common to all GDI motors I'm aware of is this silly practice of driving the HPFP off the cam giving a leaking pump direct and unchecked access to the crankcase. And sir, eventually the ALL leak. Your job is to "catch it if you can". Yes, these are the same people that removed dipsticks from engines and transmissions in belief Joe Average wasn't capable of checking, reading and maintain his own vehicles fluids. Sadly  and in large they were correct. Most people these days can't tell a sparkplug from a fire plug.  Great ideas one and all.    Every move and every error calculated to defend themselves from the law and their own customers.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
