New to forums
Shadowarcher
Hey yall, been getting tons of info on how to do this and that to my truck...figured with as much time as I spend on this site, I might as well make my presence known. Anywho, I've got a 2002 Sierra 1500 Z71. She's got 130xxx miles on her right now, by the way she running, I'll probably have her for another 100k(at least I hope). Hopefully the knowledge gained from this site will help me get her there!
