Shake up at RYR
Elwood
Yates puts son in charge of NASCAR operation
By JENNA FRYER, AP Sports Writer
December 18, 2002
CHARLOTTE, N.C. (AP) -- Robert Yates made sweeping changes to his NASCAR operation Wednesday, putting his son in charge of daily operations and moving crew chief Todd Parrott into management.
Doug Yates will be the general manager for the Winston Cup cars driven by Dale Jarrett and Elliott Sadler while continuing to work with Yates Racing Engines, which has a strong lease program in NASCAR.
Robert Yates, car owner since 1989, did not indicate how Doug Yates' increased involvement will affect him or if he will continue to be at the track every weekend.
Parrott, meanwhile, will move from Jarrett's crew chief to director of competition.
Brad Parrott, Todd's younger brother, will be Jarrett's new crew chief and Raymond Fox III will call the shots for Sadler.
``It's our primary goal here ... to win races and compete for championships, and I think we're on the right track to do that by increasing our depth in the personnel area,'' Yates said.
Although Yates' cars finished in the Top 10 this season -- Jarrett was ninth and Ricky Rudd ended up 10th -- it was a trying year for the car owner.
He was hospitalized with chest pains during activities surrounding the season-opening Daytona 500, then squabbled with Rudd through most of the year over their plans.
Yates wanted to hire Sadler to replace Rudd at the end of this season, and the split was not smooth.
When it finally seemed as if things had settled down, crew chief Michael ``Fatback'' McSwain negotiated his own release from Robert Yates Racing despite being one of the main supporters of Sadler's hiring.
All the while, Doug Yates had indicated he would like to move into an ownership role in NASCAR. By taking over the day-to-day operations, he's priming himself to eventually take over the family business.
Todd Parrott, Jarrett's crew chief for seven years, will now oversee chassis design, car construction and development and testing for both Cup teams. He will also support the crews during races.
Brad Parrott returns to RYR after spending last season as crew chief for Jeff Burton's Busch Series car, which won five of the 13 races in which the team entered in 2002.
``It's an opportunity I had always dreamed about,'' Brad Parrott said. ``Who better to further your career with than Robert Yates and Dale Jarrett, while having Doug Yates and Todd Parrott overseeing that team effort?''
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
