Backspacing question
plunk77
Almost ready to pull the trigger on some wheels and tires. the wheels i'm looking at are the XD Hoss 20x9. I want to run 295/55/r20 Nitto Trail Grapplers. The question i have is about the backspacing. The place I'm ordering them from has either +18mm and +30mm. Which one of these will allow me to not have any rubbing? Or which one do you think will work best? Yes I have a 2" leveling kit
+30 is going to be almost identical to stock, +18 will put the tire almost even with the fender. My suggestion would be the +18, they will give you more of a wider stance and should pose minimal issue with rubbing.
Yes, the +30mm will be the safest bet, because they are just like the stock offset, and will keep them tucked inside more. But, I also agree that the +18mm will look better...even if you have to trim a little plastic.
anyone have a picture of either of these? or at the least a +18mm? doesn't have to be these specific rims just something the same size
18x9 +18, the tire is a 33x12.50 so it won't stick out quite as far if you're going with tire that isn't as wide. Just look at the rear, the front is out farther because of lift.
That's exactly the look I'm going for. Thank you. Guess its the +18mm then. I'll post pics when I'm done but I can't do it until i get back from college in May so it will be a little while
also just double checking, bolt pattern is 6x5.5 right?
I can't decide whether to do 285/55/20 or 295/55/20. Pics should be coming second week of may if all goes according to plan. hopefully no large costs pop up between then and now
will i need more than just a leveling kit to fit without rubbing then?
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
