Can I slide this under a K2500 hood?
chevy4x4trucks
Hmmmm, I'm thinking that it just might flatten your front suspension out there Jp.  A tad bit more weight then a 350.  Besides, why would anyone want a Cummins diesel under the hood of a pickup?   ;)    ;)    ;)
Ah, just crank the Torsion bars.  Everybody's doin' it!  :0
WOHA! A WHOPPING 150 HP!!  im so scared  :D:D:D
is that in ur tractor or something?
Hook your F-150 up to her, we'll see which one wins.
Actually, tractor horsepower is measured differently than with other motors.  Tractors are measured at the PTO shaft and sold on that rating, not measured at the flywheel like motors in trucks, cars, or other vehicles.  This engine actually has 250+ horsepower at the flywheel, but due to the losses from the transmission, clutch, and other assorted areas not all of it reaches the PTO shaft.   :D
Yeah, its the motor in our 7220, its my experience with these Cummins (we have two of these) that makes me believe they are the best diesel motor out there.
See Paco, you just learned something today, not that you really wanted to know that though.   :D
Much the same way as chassis dyno's measure power at the drive wheels.
Almost, but not quite.  When they run drawbar pull tests on a tractor is when you could compare a rear drive wheel dyno test of a truck or car.
Here is the PTO that is used to take these measurements.
Gotcha.  :D
JP  That looks like a sick John Deere.   :D
If you ask me, I think all the green machines are a bit slow.  Always a bit sluggish and out of energy.   ;)
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
    • Stabilitrack was a stability control, traction control system, that functioned independently from the transfer case.   Z-71 has nothing to do with the transfer case or differential.   If it does have an AWD system, my memory recalls this being specific to the Denali trim, converting won't be as simple as swapping out mechanical parts like differentials and transfer cases. It will require reprogramming at a minimum. Long story short, not likely worth it.   Pulling a fuse, may disable the AWD system, it might also prevent any other transfer case functions.   However, the AWD case was generally based on the same transfer case you refer to in the 2006 Suburban. If it still has a 4-High and 4-Low where the transfer case locks and splits power 50-50 front to rear, what are you gaining by changing anything? A true-rear wheel drive only, what good will that serve? Not enough to go through the trouble of changing out all the parts.    Generally, all the factory systems will handle a 33" tire and re-gearing. Probably a 35" tire too, if you aren't driving like a caveman. If 35" tires are in the plan...   If you do plan on driving like a caveman or are fully committed to 35" tires, an entire re-think of the build is probably in order. Starting with square one, an IFS front end isn't going to be the best starting point for 35's and caveman driving.
    • 1/2 qt over full ain`t gonna hurt $h!t. Most times, a whole qt won`t either. Most have windage trays now. As long as the crank isn`t slapping itself in the oil, it`s not the end of the world.   We used to overfill 1 qt at the track, at race time. Better to have it over full than having the pan sucked dry at 6500 rpm`s.
