Spring Cleaning
Pknitty86
Finally got to cleaning the truck the other day and was able to wax it for the first time. April 7th marked the 1 year anniversary of me driving her off the dealer lot . I can't believe it's been a year already and it’s been a great one!
Its funny I am getting my mom to clean my truck all nice . Wax it , and detail it and clean the inside when I am gone commercial fishing for 4 months in about 2 days :( I am going to miss my truck lol .
