New to GM
Hi I just purchased a 99 yukon and am liking it thus far, I am a avid offroader but this is my first north american wheeler, Ive always had toyotas and figured what the hell lets see what this unit can do,
questions
Best lift (bang for your buck) and no plans on a sas at the moment.
and quick bolt on hp? (5.7)
looking forward to the help
Welcome to GM and to the forum.
For your questions I'd suggest that you check out the Chassis & Suspension as well as the Engine & Powertrain sections. There are lots of threads that should give you some ideas of what others have done. Good luck & Happy reading!
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
