On another note for others coming to this thread for help with clunking noises. Generally if you get one clunk when going forward and one when going in reverse it's usually a loose upper c/a bolt.
Sent from my LGLS990 using Tapatalk
  • 5 years later...
2018 Suburban with less than 20 K miles, has the same problem, making the "Pang" sound  once or twice during backing and reversing. I took it to the dealer's shop, and they can not figure it out.  I have a few month to run out of warranty, I am not sure what to do with it. Any suugesitons?
  • 3 weeks later...
So I have an 05 Tahoe and when I'm reversing to park ,wheels turned hard right there is a bad clicking sound . Changes tie rods and lowr ball joint and still clicking . Any help will be highly appreciated. 2wd
Edited by David Towne
I’ve been experiencing a “clicking” in my steering at tight turns when parking. This began shortly after a 2.5” level instal on 2016 Sierra. I’ve had suspension looked at twice, along with the alignment after instal. No concluded damaged parts.
My research is indicating it to be a cv joint issue, but boot isn’t leaking, or possibly electronic power steering issue.  If I gather more definitive info I’ll post it.
  • 1 year later...
I have the same thing going on but just on the right side. I did just replace the lower control arms on both sides. It’s a 2wd.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
