Got my 1/4" spacers on had enough clearance to creep home.. alignment is on Tuesday my 1" spacers also come Tuesday so looks like Tuesday ill be back to normal I hope
Sent from your truck via Tapatalk
Picked up my study materials for training today haha!
Have to know everything in there by the end of the month, let the studyfest begin haha!
Sent from my SCH-I535 using Tapatalk 2
Edited by baikenbitz
Drove to the Surgeon's office. A little fun in the rain
Drove to work in the rain. Moved some tires for Sarah... first are Pit Bull 41.5 x 13.5 x 17's. Second are 385/70/17 Nitto mud grapplers.
You coulda mailed me those 385s lol
I thought you'd like those Sarah. They are pretty cool, hadn't seen them up close before. Side wall is bad a$$, and the "bear claw" at the end of the tread blocks is a cool feature. Probably would need a gear change, not only for the size but for the weight as well. My scale showed four of 'em weighing in at 410 pounds. Cool tires. Your lift looks good. :thumbs:
cleaned up my engine bay while my bro changed his oil in his car at my house
Here is the before and after shot of my brothers engine bay (08 malibu, 67K miles never detailed engine bay). Only took about 15 min.
Edited by RyanbabZ71
What are you using to clean? I need to clean off some oil field mud that's trapped in there
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Put on a coat of blue dodo juice wax today :) Its almost cruising season
What are you using to clean? I need to clean off some oil field mud that's trapped in there Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
First step I used Adam's APC.
On my bros car I then put on some poorboys trim stuff I had that I am trying to get rid of. Works great but I dont use it on any of my vehicles. The truck I didnt put anything else on it just APC.
I looked at my corsa system for the first time because I was in the hospital when it was delivered. Amazon boned me twice. 2 orders and neither were correct. One order I only got box 1 of 2 and the other order I got 2 of the box 2 of 2's
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
