Chris send them back if they're wrong. Have you talked to BBP? They might be able to get you a good price.
How'd the install go Carder?
Today I drove around, roads all wet. Tons of drunk people everywhere for Fake Patty's.
I talked to amazon, between the 2 mistakes I have 1 and 1/2 systems. The rep at amazon said to keep a complete set and send the 1/2 set back for a refund and he was marking it on my account as an incomplete shipment. They are making it right
Install wasnt that bad, took about 3 hours, would have been less but we had some issues with the cats so we had to cut some piping off. Some key pointers to help you along, remove the intermediate steering shaft on the left side to get the headers in, and also remove all or most of the spark plug wires and plugs if you want too, I left mine in and didn't have any problems.
They like Doug thorley
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Yeah it'd be Thorley LT's. With those and my Magnaflow it would sound pretty good. The ceramic coating on the Thorleys looks really good. Hopefully they'd add a little towing power.
Installed the corvette servo.
Like it? Noticeable difference?
Sent from my SGH-I927 using Tapatalk 2
Yeah. Shifts are a whole lot better now. Very noticeable on mine, would probably feel like new on a more worn tranny.
The servo helps a lot. I had one put in during the 6.0 swap
Mmmmmm been considering it
$20 bucks and its one hell of an investment!
How hard is the install?
As easy as pulling a snap ring
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
