you might need more hose? Just be aware
Went to the lake to boat today with friends of ours
Went to Advance Auto for some 3/8" fuel line, and hose clamps. Then I installed my catch can.
Then I went to put my new 4x4 decals on, but decided it looks better without them.
I didnt use hose clamps on my car or truck. Seems like over kill. The lines wont come off unless you forcible pull them off.
Really. I figured they were something you would have to use. Oh well I guess they'll just be extra insurance for me.
I wired up my lights today too. Just got home from trying them out.
Did a little free/cheap DIYs
Painted the silver accents black (minus gauge surround, will get to it)
468C6943-E2C6-4A51-B96F-E1B739A1AAC3-275
Looks a lot darker in the picture it's closer to the button color, and looking at it, I need to paint the Chevy logo.
09F025C8-406E-496B-A392-3C06304457B9-275
Also finished up the antenna delete DIY, now hunting to find a cap for the spot.
Edited by Alex@BBP
Finally ripped that stupid radio in the back out no more whistling
Now it's badass
I got in a small accident
Sent from my Samsung Galaxy S4 using Tapatalk 4
Uh oh. What happened?
Semi drifted and guard rail came out to the white line
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
Left doors are dicked. So is the fender. May be able to fix the bed. Left mirror is gone
A semi was in the middle lane drifting over and I was riding the white line in the left lane doing 60. He started drifing over to my lane and I had no where to go
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
