How much steel is it? Is the smoker still good?
Might be eight rotors, bunch of shocks, random bits of metal, and some of my old exhaust to include the old cats and one manifold off my truck. I think the cats alone can get you a maybe $50?? I don't know what the metal inside is worth. As for the smoker, it still works, has rust on the outside and some in the fire box but all the grates are there to include new thermostat I put into it a while ago.
Dang yea ill take that stuff off your hand. How soon do you need it gone? I'll be back in that area in a month for spring break?
Give me a date and I'll see. Any weekend is good as long as it's not the last week and a half of March.
Washed truck and garage floor
Before
After
Ryan
Washed truck and garage floor aqypyre7.jpg Before gyjypuhu.jpg After be3uquvu.jpg Ryan
Hey, there is a Z-28 Camaro calling your name, and it also said that other camaro was in its space. Probably should move it!
As cool as a Z/28 would be it's not really a normal driving car.
Ryan
Took the truck to Bismarck for the day, Wife had a nursing conference down there.
your daughter has a sweet ride
Yea she has an assortment
Ryan
As cool as a Z/28 would be it's not really a normal driving car. Ryan
That is really subjective to who you ask as a "normal driving" car. I would drive it everyday, speed limit too!
Have fun in the middle of summer with no AC
Ryan
Ryan
AC is an option. ;)
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,012 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
