Chevorlet Silverado Blackbear Tuned Core Modules PCM/TCM
I sold my struck and that was custom tuned by Justin at Blackbear, I put the stock PCM/TCM modules back in before selling. Blackbear sells the cores for $220 for both the PCM/TCM, If you are looking to get a Blackbear tune and want to keep the stock modules, I'm selling my tuned modules/cores for $150 and will ship them for free anywhere in the US this will save you $70 if getting you were planning to get cores from Blackbear. They came off my 2008 Silverado LTZ Crew Cab 5.3 V8 with 3.73 gears.
Bump, I really need to sell these, I will let both the PCM/TCM go for $100 and will ship free anywhere in the US!
Yes, according to blackbear performance website, it will fit 2007+ models since it is the gen IV engine computer.
If you have the same setup as him, tranny, motor and gears you can plug them right in and it will work. You will have to do a crank relearn though. Otherwise, its an extra set that you will need to send to BBP to have tuned to your liking.
Sent from my DROID RAZR using Tapatalk 2
Correct as JdubUB said, if you have the exact set up as me, you can plug them in and crank relearn, would would save you a ton, I paid $550 for my tune, I was mainly selling them for those who wanted to keep the stock modules for when they have there truck serviced at the dealer. If you are wanting to keep the stock modules, you would send these (the ones I'm selling) to Justin at Blackbear and he will tune them according to your truck and what you want. Justin at BB charges $220 for the core modules so you would be saving $120. This is only good if you want to keep the stock modules if your truck has any warrenty issues, so then you can just put your stock ones in when serviced, unless you have the exact set as my truck then you can used them as already tuned.
Won't they need to be retuned for whoever buys them? The tunes should only work on your truck right?
Sent from my iPhone4S
using Tapatalk
They will need to be re-tuned and should be re-tuned. Every vehicle setup is different. Trans shift points, line pressures, tire size, gear ratios, etc
I see you say it Will it work on a 2012 but am just wanting to make sure 2012 didn't do something different. Looking so I can tune out afm and return to stock if warranty work is needed
Anyone know if this will work on a 2012. I'm looking for spares to send off and have tune to my truck
I believe they should......
If it was for the 08 in his sig its a 4 speed
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
