03 4.8 Fuel Mileage
Have a Quick question for you Guys. I recently Bought a new to me truck, a 2003 Chevy 1500 ext Cab short bed 2wd with the 4.8 in it. has 160,000 Miles on it. The issue I'm having is Fuel Mileage, I'm getting about 12-13 in town and 15-16 on the highway, The thing that I know is hurting me is the 20" Wheels on it, They throw the Speedometer off about 5mph at 65 but I still think it's below average. it runs ok. some times it seems like there is a power loss and other times it has no issues at all. it has about 30-40k old Plugs and wires, New Cats (old ones started Rattling) Short tube Headers and Cherry Bomb Extreme Dual Exhaust, Cleaned the Throttle body and MAF and ran some Seafoam through it for the heck of it, about the only thing left that i know to do is put some o2 Sensors on it and clean the Injectors, no Engine light or anything along those lines. if there is anything I'm over looking let me know i'm just kinda at a loss and looking for Advice.
Thanks in advance.
-Robert
I get between 15-17 averaged out for the week. About half the tank is hwy. The hwy is stop and go sometimes because of a lot of end of fiscal year construction. I have 20s. Speedo is 1 MPH off. What gears do you have. I have 3.42's
Sent from my PIECE OF CRAP DROID X2 using Xparent Red Tapatalk 2
i have a 2003 4.8 with 285's and 3.73's and i get about 13-15 city. maybe a little better on the highway so that might be about as good as your gonna get with that truck.
  • 1 month later...
That doesn't sound right cause I have an 05 Chevy 1500 4x4 4.8L regular can short bed sitting on 40s with 4.88 gears and I get 14 to 15 mpg
Also do u have a base model truck or do u have a display of your average fuel mileage because if your speedo is off your not going to get an accurate distance or mileage trip so that u can compare the distance and amount of gallons ran through it your calculations will be off because it throws your odometer off so you really have more miles on your truck than you think
And make sure you clean or change your air filter, fuel filter check tire pressure, change oil regularly and use good recommended brands and run some kind of cleaner threw the engine and fuel system to clean it out incase an injector might be stopped up or it might not be sparking correctly and just dumping excess fuel into the cylinders I would check all those things before going to expensive repairs
  • 1 month later...
my 2001 chevy silverado has 4.8 engine and i believe 3.42 gears,magnaflow single in dual outlet exhaust.. bought it 6.5yrs ago and have always averages 16/17 mpg... even on the highway stays right at 17. and i drive like a grandpa most of the time..
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
    • Great video. I almost want to reserve one now.
    • I traced the atf cooling system in my 1500 and it comes out of the transmission, into the bar/plate liquid/liquid heat exchanger, as stated above.  Then it crosses over to the external thermostat/bypass and then  to the aux cooler in front of the main radiator.  Hence, on this routing, the PPE thermostat bypass eliminator is an $85 piece of bling that does nothing for reducing atf temps on this truck.  I think I'll temporarily clamp a needle nose vise grip on the coolant feed hose to the bar/plate cooler and see how much the atf temp drops.  With the use of ULV trans fluid, I'm not convinced running the trans cooler than OEM spec is going to be detrimental to the life of the transmission.    I found this interesting on the Dana/Long site stating that they make transmission cooling/heating bar plate heat exchangers.  I worked with Dana/Long on a few projects when I was at the gas powered fun factory. https://www.dana.co.jp/downloads/PTG/Long/Dana_TOC_SpecSht.pdf  Bar plate heat exchangers are just a stack of stamped parallel path fluid channels, assembled and vacuum furnace brazed to make the final assembly.  Want more cooling/heating, just stack more plates until you run out of package space.   Anyway, thanks for the info, much appreciated.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
