Trailer Brake wiring problem
lescan
Hi. I have a 2002 1500HD 4x4 when I hook my trailer up to it everything works, running lights, brake lights,indicator's except my trailer brakes. However when I apply the brakes using the manual switch on the brake controller they work just fine. They will not work when I apply the brake pedal.
Any help or ideas is really appreciated.
Since the brake lights on the trailer are not coming on when you press the brake, then I would think the brakes on the trailer are not either.
Check the wire from the controller to the brake light switch.......
Many thanks for your prompt reply. Sorry if I was not very clear, but the brake lights are coming on on the trailer. The trailer brakes work fine using the manual switch on the controller but when I push the pedal no brakes on the trailer.
Appreciate your time and concern.
Les
The blue wire from the controller is not getting the brake light signal from the truck - probably an issue with the under hood connection. Reference this to troubleshoot: http://www.etrailer.com/faq-cbc.aspx
EDIT: with your brake lights functioning, this will be a tricky one. Sounds like activating it manually gives the wire enough voltage to overcome a possible loose connection ... but hitting just the brake pedal isn't supplying enough voltage.
Well many many thanks to you ALL. After following the above post link to etrailer I read and followed more links and finally found that the CHMSL fuse had blown. I had never heard of this fuse but etrailer directed me to the exact position.
Once again my thanks to you all, a GREAT bunch of guys that give their time to us that know very little.
Problem solved.
Regards Les . :thumbs:
Good deal - glad it worked out. :cheers:
The only lingering question in my mind is .... why did it blow to begin with?
If you do end up with another blown fuse in the future, wire a 12v bulb in place of the fuse - if there's a short that will blow the fuse, the light will be lit fairly bright. Unplug or disconnect the wiring in the offending circuit until the light goes out, & when it does you've found the circuit with the short. Repair it, then check the light again to make sure it's fixed. Saves you fuses, and a few headaches as well.
Many thanks for your reply. I can only assume that after I found a cut in the 'trailer cable' and found a broken wire it had shorted out.
After rewiring the trailer cable thats when all this started. First a blown turn signal fuse, replaced it that was ok. Then when I tried the brakes nothing. Checked the truck plug-in and found a corroded wire feed to the brake, so replaced the plug-in as as it was a factory install. After that was done thats when I found that the manual switch on the controller worked but not the brake pedal. Thats when I searched the internet and found this great group.
Once again many many thanks for the help.
Regards Les
