Sometimes my amperage gauge will drop to about 10 or 12 but it usually stays a little over 14. Is there something going wrong? I don't have any amplifiers or anything extra that would pull a load on the electrical system. I did an alternator and battery test and everything was fine. Here are pics.
It was actually lower than this but by the time I snapped a pic it had started going back up.
And normal
Mine does that too. I have a 2009 Silverado with a 5.3 L engine. I would like to know also.
Normal operation. Read your manual, it's supposedly more efficient this way.
Edited by MikeNH
The alternator in these newer vehicles are what is called "free wheeling" that is to say when the battery is fully charged, the alternator "disingages" via a clutch so even though it is connected to the serpentine belt, it is not causing any drag on the system, thus the gas savings. I PERSONALLY DO NOT SEE A GAS SAVINGS ON MY VEHICLE.
Not quite. No clutch or any fancy stuff, it just backs off the output.
Every .0001 of a gallon counts when you try to beat the C.A.F.E. ratings
Point well taken :)
Edited by Gurrzt
It is called Regulated Voltage Control . :)
And there are 6 different states of it, according to my Helm manuals.
I'm just curious as to why my voltage starting "dropping" after a couple of years of driving. The voltmeter was always constant at ~14 volts then one day it just started dropping and raising and has ever since. I'm always scanning my gauges, pet peeve of mine. I found out it was normal operation but to not see it happen until after a couple of years driving???
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
