Before and After
SarahsGMC
i dont know if you guys already have a thread like this if so disregard this but basically just do a picture or a few of when you first got your truck and then present pics to see how much it has changed
with color matched mirrors, handle buckets, and fender flares.... would have a nice truck.....which already looks pretty sexy love smoked headlights....
It stayed stock for maybe a day.
3" body lift / 2" level / 305/55/20 Nitto Terras and 20x8.5 Liquidmetal Magma wheels
Bullbar/Bowtie/Door Handles
6" BDS / 3" body lift / 325/60/20 Nitto Terras
No more bullbar / Painted front bumper / Tow mirrors
Blacked out front end completely and rear bumper
Wheel swap - 20x10 black Mazzi Hulks
37" Nitto Trails
here is my before and yet to be continued after photos, let me know what ya'll think
Wow that thing is sharp!
i just ordered a replacement grille and overlay for it so once i get it on ill post another picture ..... she has some time invested in her........
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
