Dual Battery Setup
I have a 07 sierra 1500 that has alot of electronics and has the option for a second battery, anyone done it? know where a good place to get a kit for it?
You really don't need a kit, just another battery and some cables to reach your OEM battery.
Ur right but the kits will keep you from draining both batterys, allowing you to have a back up
Sent from my iPhone4S
using Tapatalk
Sent from my ADR6400L using Tapatalk 2
thanks for the info... i deff wanna make the second one a backup
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
