Design your own offroad packag!
HillHound
Let's see what kind of stuff some of you guys would include in a factory offroad package.  Keep it isolated to pickup items and remember this is for a factory package, which means it can't be too expensive and still had to be functional as a daily driver and street legal! :cheers:
Here's what I would do:
Gas tank, front diff and trans case skid plates.
16" Alloys with real all-terrain or mud-terrain LT tires.
Fender flares.
Heavy-duty tow hooks.
Manual Rear locking diff.
4.10 or 4.30 differentials.
Delete carpeting in the cab.
Offroad tuned shocks of course.
Tow hitch and transmission temp guage with tranny cooler.
Non-chrome bumpers painted with some tough paint like maybe bedliner coating.
Digital compass in instrument cluster-not in overhead panel.
Maybe if possible some special paint schemes available only for the offroad options.  Maybe dark green, tan or brown or dark metallic red with matching fender flares.
full face steel wheels
manual tansfer case
heavy duty tow hooks
4.10s
full guages
spray in liner
2.5" factory lift
all terrain BFG 285s
off road shocks
skid plates
rubber HD floor mats
anti-chip protectors for lights (clear plastic sheets)
HD cooling
SFA
locking diff
also, it must be available on base models!  currently base models are neglected by all brands when it comes to OR packages!
This:
Dimensions:
Engine:
Height
6'0"
GM Vortec
205 H.P.
Chassis Width
30"
Transfer Case:
Overall Width
85"
Atlas II
4.3:1 or 3.8:1 or 3.0:1
Wheelbase
99"
Klune V
2.72 or 4.1
Overall Length
133"
Axles:
Weight
3200 LBS
Dana 60's
Ground Clearance
22"
Avalanche Engineering Advantage
Approach Angle
90 deg. Plus
Avalanche Engineering High Mark
Departure Angle
90 deg. Plus
OR
This
The Scorpion
MKIII - Diesel
Cummins Diesel Power - Features
Seating: Four
Engine: Cummins 4 cylinder Turbo Diesel 3.9L 130 - 170HP
Transmission: TH400 3 Speed Heavy Duty Automatic
Transfer Case: Atlas II 2-speed 4.3 to 1 Low Range
Frame: 2" .125 Wall D.O.M. Tubular Uni-Body design
Body Panels: Aluminum Tread Plate - easily replaceable
Brakes: 4 Wheel vented disks
Weight: Approximately 4600 lbs.
Ride Height: Variable
Available colors: Our favorites are Desert Tan, OD Green and Rescue Red but we can accommodate most requests. Just provide us with a paint code or a color chip. We use only the best in automotive paints.
Some Options: Soft Top, Hard Top, On-Board Welder, 2 seats, fording kit, Beadlock Inserts, etc...
Many custom features are available upon request.
I guess these are not options on a truck, but if I win the lottery, they would be an option buy ;)
Well for a factory package working from existing GM stuff, I'd say...
6.0 Caddy Engine
3/4 ton suspension components
14 bolt rear end w/ 4.10 gears
Floor shifter for t-case
33" tires on a 3" factory lift
rancho rs9000 shocks w/ the in cab adjuster
on board air compressor
full size spare w/ optional bed mount
on-board cb radio option
rubber floor option
black bumpers and grille
offroad lamps instead of fogs
dual exhaust
some added power
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
    • I have a 2026 base 1500 "WT" regular cab with basic Chevy "Infotainment 3" 7-inch screen/radio. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit]? [I listen to classical and it gets a bit raspy at slightly higher volumes. Don't need a sub etc.] Do I have two or 1 speakers in the doors? etc. Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
