2003 6.0 Silverado missing and sputtering under load
rgv
My work/hunting truck is a 2003 2500HD with a 6.0L and a 5 speed manual. All stock.
It has 111,000 km (69,000 miles) on it currently and runs perfect except it hesitates/misses/chugs/sputters under load between 1500 and 2200 rpm
you can make it do it on demand with the empty truck and it is much more pronounced with a load.
No error codes, the MAF is clean, fresh plugs, new fuel pump and filter, TPS tracks properly on a scantool, MAF looks normal on scantool (no apparent vacuum leak), no KR showing on scantool......
Truck gets normal fuel economy and makes good power otherwise.
Any ideas greatly appreciated!
Is the replacements fuel pump aftermarket, or GM/Delco?
I would also check fuel pressure. Maybe you got a bad replacement pump.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 292 Guests (See full list)
