91 octane fuel
I recently purchased a 2004 chevy 2500 HD with 6 liter motor, it is equipped with some obvious aftermarket items such as JBA headers and exhaust, and Vararam cold air intake. then there is a note on inside fuel door that says minimum 91 octane gas only. I am wondering if there is any way to determine if there was a tune of some sort installed on the truck that requires 91 octane fuel? Thanks for any help.
depends on the truck..I have a raylar cam in my 8.1 and ray from the company told me the big blocks like lower octane so 87 is wgat im tuned for and what i run..
you want to see a real good change or result.. go buy a bottle or 2 of startron fuel additive and/ check my post about it..The stuff is great and will instantly make your truck run right,better, and pick up 1-3 mpg,s
Contact blackbear for a custom tune, justin is the best with these gm motors.. you will see a general improvment, in idle,mpg,smoothness, and more power and TQ increase then any handheld tuner will ever make.
the 6.0 sierra i had never seemed to run any different on 87,89 or 93...buty i wasnt tuned either
with the stock tune or configueration on the 6.0 ive never had or heard of anyone having a knock.. but i guess its possible,
The 6.0L runs best on 89+ octane (91 is optimum). This is a well known fact. They will knock a lot if you run 87.
+1 - My 2011 6.0 knocks running 87.
You sir are correct. I data logged mine running 87 vs 91 it pinged WAY more on 87. In fact I was able to bump up my timing enough to gain a solid 1.5-2 mpg across the board. Running 91 is very much so "worth it" if you have it set up properly.
Ha! LOL! I guess I'm just lucky!
Not really a matter of luck, depends where you're gettin ur fuel too. They're is a few different factors that make your truck ping but I wouldn't waste cash on 91 if the vehicle wasn't tuned for it either. It has benefits but only real
Benefits are with tuning...IMO.
For sure! Yeah the stations with the ethanol probably don't help. Also I think some stations' low grade is 89.
And mine definately isn't tuned- no way! It will absolutely shred tires now on dry pavement, and that's good enough for me! :)
