Anyone try a Class 10 Micro SD for OGM1 navi?
Wondering if anyone has tried to copy their map info from the Class 4 Micro SD card that comes stock with the OGM1 to a Class 10 card to see if it has any effect on the iGo Primo map bootup time?
As you know, there is a short process that the iGo Primo system goes through to unzip necessary files. What I don't know is whether this process is affected by the speed that data can be read from the card, or if it's limited by the speed of the processor.
If possible, do a comparison test measuring the time difference (if any) from pushing the navi button to landing on the map screen on the navi using both cards. Brand/model and speed info would be helpful.
Ideally, if we can get multiple volunteers to try different cards and narrow down the best performers (if there's any difference, that is), that would be great data to have.
My guess is that a Class 10 card may speed up this process, but to what extent? If so, it may be the best speed mod you can do on this deck for under $20...
Anybody own a Class 10 card or two to try this experiment?
I'm absolutely willing to give it a try. I dont own a class 10 card, but i'm willing to pick one up. Can you recommend one?
This was the first thing I did when I got my OGM1 from you. However I never did a comparison . . . it only stands to reason that it is faster.
I will try and do a comparison and post my results.
OK, I ran several (non-scientific) tests with the Toshiba Class 4 4GB card that came with the unit and the Transcend Class 10 8GB card that I purchased (cost me $8) and surprisingly found the following:
Class 4
29.2 secs
27.4
26.9
25.8
25.7
Class 10
30.6
27.7
27.2
27.2
27.2
It would appear that the read speed of the card reader in the unit is maxed out by a class 4 card and in fact the class 4 could be slightly faster. This may be due to the higher capacity of the 8GB card.
Interesting and a little disappointing.
Class 4
29.2 secs
27.4
26.9
25.8
25.7
Class 10
30.6
27.7
27.2
27.2
27.2
This sure makes it look like the speed is limited by the processor, doesn't it?
However, after reading up on a few Class 10 cards, it looks like some are definitely more adept at large file access (large video files, photos, etc.) at the expense of fast access with multiple small files (which this qualifies due to the data.zip and branding.zip being 31MB and 494K respectively). I'm no expert at which cards function better in which scenario, just that some are better than others for each task.
Don't know your Transcend card stacks up in this regard...
Does iGo extract the zip to the card? I thought it is directly to memory to avoid taking up too much storage space but I could be wrong on that.
Zip compression is extremely processor intensive so unfortunately we probably would not benefit from a faster sd card :( but would love to be proven wrong.
Ernie
I've tried PNY and Kingston before using "SD Tools" (play.google.com) and they never managed to live up to their class rating. I've stuck with San Disk, they always meet or exceed their ratings. You can get a San Disk Micro SDHC Class 10 64gb for $40. Its what I use in my Galaxy Note.
Both cards I tested exceed their class rating (which is easy to do given the Class 10 minimum speed is 10MB/s). Writing is the slow process for the class 4 card vs the class 10 card I tested.
Unfortunately many readers max out at around 20MB/s for reading which is what I suspect is happening here since both cards can achieve that speed when tested on my PC.
    • I just bought this. A minimum for me but, I don`t work anymore and don`t want the heavy update costs of the higher end tools. You would have to make money with them.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Even this tool has a $250.00 update cost after 2 years.
    • I have an Autel, works great for what it is. Can't do some specific things because you need say the GM tool, VCDS for Audi/Volkswagon and others of course. But those times are few and far between for me.   The other tool I'd like to try one day is the new Topdon scan tools. Seen several video's on them and many youtube people review them.    I've never subscribed for updates or payed to do that stuff on my Autel, so I'm sure I'm missing out on some of the updates but I'm fine with that for now.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
